Gear stick gater cover HELP
Mar 3, 2008
807
sunny Devon
hi people does any one no the part number for the black square plastic clip,that clips and sercures the gear stick gater to the to the top of the gear stick housing?
rang my local dealer and they said i had to buy the gaiter as well? and gave me a price of £80? which i am 100% sure they have cocked up?
mine has a few chips in it only changed the gear knob 3months ago,and now i want to change the black clamp ring to make it look smarter:D
some one helpplease
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
You can re use the black plastic ring if that helps?
Unless I'm missunderstanding....you mean the ring that clips into the big hole that holds the gaitor?
Mar 3, 2008
807
sunny Devon
no i want a new black ring. mine has chips in it shows threw black,got white spots black is missing
( IM AFTER THE PART NO.& PRICE FOR THE BLACK PLASTIC RING PLEASE);)
jcborden
Don't know the part number, but had the same problem with mine. Took it off, rubbed down, primed and spayed black then a couple of coats of lacquer and it looks just fine.
D.K
LCR 225
Oct 24, 2007
6,408
se london
Stop being tight and buy one of these
I dont think you can get just the ring mate, You'd probabley be better off spraying it.
