nathwarr said:I'm not sure if thats right as my brothers pd130 sport does aprox 80mph at 2000rpm in 6th gear......??
dmjw01 said:The FR has shorter gearing than the Sport.
T. Spark said:On the road, well this means Mikes whoooops Ed's ass
T. Spark said:Depends how your car is set up? Is it standard? Have you had it on some rollers?
When mine was standard I found 4k best for changing.
Yes, well i beat all of you , like a bunch of little girls ffs, i beat you, no i beat youMike_obd said:To work out when the best time is to change gear is to have the car rolling roaded then go from there....
Ed... i did catch you up and i beat you as well so ner!!
j.a.kelly said:yeah i agree, 2000rpm @ 80mph on a sport. Quite good on a motorway run really, jus i find this slightly different to my previous Bora 6speed, in the bora i could sit @ 70 in 6th and it would have loads of go...
the ibiza prefers 5th for more power, and then back to 6th
JK
edit: good work tho mike, knowing u you probably actually tested those revs/speeds too - on the JBS test track
