gear box
richy_t
86
i am havein a bit of a prob with my 1.6 wen in ideal there is a funny tapping noise but wen i dig th clutch it stops if i let it back up it starts again. any ideas?
kalwelch_33
check the gearbox oil level, it might just be low. Sounds like what happend to me, i topped up the oil and it was fine but then a few weeks later the box just gave up on me..
G223
303
the only thing holding oil in my gearbox is the cv boots :D and thats technically its 3rd gearbox in 120000 miles
Feb 8, 2007
108
Aberdeen, Scotland
the gearbox's are well soft on some ibiza's, mine is on it's thjrd at least, i replaced it, an it looked like the one that was on it was a replacement! an since tyhen i've not really revved past 4000prm, an this one sounds unhealthy aswell!! aaaaahh
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
sounds like the clutch release bearing, or the centre bearing on the 'box
mine did it for 75k (I picked the car up with 50k) and it was fine
Dec 17, 2006
1,837
Bristol
There's an allen screw on the side of the gearbox which you need to take out. If the oil is level with this hole, then it's got enough oil. If you need to curl your finger down then it needs topping up, which is doen through the same hole.
