Hey,
This has happened almost a year ago from now.
Changed the stereo from the exeo to a Alpine W296BT, when installed, all wired up, started the car i think i heard a little "snap" and smelled little smoke. After turning the car on just fine, the EPS & Tyre pressure lights came on, this apparently is common when disconnecting the battery and should go away after little driving. It did, but it came on after few kilometres.
It would come on after every slight turn to left or right, but adjusting the tyre pressures helped alot, i could drive 100km's without any warning but it eventually came back. Tried resetting with VCDS, calibrating it again following the guide, no luck. Checked the fuses, relays and no luck there. The one relay near the ECU box was little loose but didnt affect anything.
Address 01: Engine (J623-CAGA) Labels: 03L-906-022-CAG.clb
Part No SW: 03L 906 019 B HW: 03L 906 022 GE
Component: R4 2,0L EDC H04 6559
Revision: 11H04--- Serial number:
Coding: 0304002C18072118
Shop #: WSC 06441 785 00200
ASAM Dataset: EV_ECM20TDI03L906019B A01003
ROD: EV_ECM20TDI_SE41.rod
VCID: 2A5B199E4D077B7110B-807F
1 Fault Found:
5130 - Oxygen (Lambda) Sensor B1 S1
P0130 00 [032] - Malfunction in Circuit
Intermittent - Not Confirmed - Tested Since Memory Clear
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H HW: 8E0 614 517 BF
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004401
VCID: 2C571F868FF36541E27-8079
2 Faults Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 116
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4002
Hex Value: 0x0024
Hex Value: 0x01A9
Hex Value: 0x0001
00532 - Supply Voltage B+
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Time Indication: 0
Freeze Frame:
Hex Value: 0x0B00
Hex Value: 0x4002
Hex Value: 0x0003
Hex Value: 0x02AB
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 06441
VCID: 6DD1D2822769AC49B59-517A
No fault code found.
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00011
Shop #: WSC 06441
VCID: 3D7122C23789FCC9459-4B1A
Address 15: Airbags Labels: 3R0-959-655.clb
Part No SW: 3R0 959 655 HW: 3R0 959 655
Component: 04 Airbag 9.41 H15 0010
Revision: 91H15001 Serial number: 003E9000ZDMA
Coding: 0012340
VCID: 7CF7EFC63F1335C1327-8029
Subsystem 1 - Serial number: 6332DRB40B1890A9V
Subsystem 2 - Serial number: 6342DRB40B1891B0P
Subsystem 3 - Serial number: 6352ARB405778325J
Subsystem 4 - Serial number: 6362ARB4058D636BZ
Subsystem 5 - Serial number: 63747RB40583CDE61
Subsystem 6 - Serial number: 63847RB40583CE1E+
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0801
Coding: 02041
Shop #: WSC 06441
VCID: 41895E324B719829211-4B02
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 17: Instruments Labels: 3R0-920-xxx-17.clb
Part No SW: 3R0 920 800 E HW: 3R0 920 800 E
Component: KOMBI+WFS 4 H03 0020
Revision: 0020 Serial number: 00000000000000
Coding: 0006118
Shop #: WSC 11800 205 92522
VCID: 2D511282B7E96C49F59-515C
1 Fault Found:
01304 - Radio
004 - No Signal/Communication
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0006118
1 Fault Found:
01304 - Radio
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CL
Component: Komfortgerát T01 4336
Coding: 06720
Shop #: WSC 11400
VCID: 7DF1E2C277093CC9059-4B1A
Subsystem 1 - Part No: 8E1959801H
Component: Tõrsteuer.FS BRM 0606
Subsystem 2 - Part No: 8E1959802H
Component: Tõrsteuer.BF BRM 0606
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
Address 4C: Tire Pressure II Labels: 3R0-907-274.clb
Part No SW: 3R0 907 274 HW: 3R0 907 274
Component: J793 RKA+ H02 0002
Revision: 00000311 Serial number: 00003110346022
Coding: 0000065
VCID: 72EBC1FE6D5773B168B-8027
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 3
Fault Frequency: 216
Reset counter: 128
Mileage: 144502 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 11.90 V
Temperature: 13.0°C
(no units): 0.0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 127
Mileage: 144502 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 11.90 V
Temperature: 13.0°C
(no units): 0.0
End-------------------------(Elapsed Time: 04:24)--------------------------
thats the whole scan. It goess off everytime the car is shut down, now it comes on after 20-30 km's or so, and whats wierd it always comes back almost at the exact same spot on my way home, give or take 100-200metres.
Im getting tired of this, is there any way to check the code for new g85 sensor without pulling the steering wheel apart? apparently its somehwere in 150-200€ mark, hopefully not more, stereo change became little expensive ehh
1 Fault Found:
Coding: 0004401
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 3
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4002
Hex Value: 0x0024
Hex Value: 0x01A9
Hex Value: 0x0001
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 30
Time Indication: 0
Freeze Frame:
Hex Value: 0x0B00
Hex Value: 0x4002
Hex Value: 0x0003
Hex Value: 0x02AB
Hex Value: 0x0001
Coding: 00000
Shop #: WSC 06441
Coding: 00011
Shop #: WSC 06441
Coding: 0012340
Coding: 02041
Shop #: WSC 06441
1 Fault Found:
01304 - Radio
Coding: 0006118
1 Fault Found:
01304 - Radio
Coding: 0006118
1 Fault Found:
01304 - Radio
Coding: 06720
Shop #: WSC 11400
Coding: 0000065
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 128
Mileage: 144502 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 11.90 V
Temperature: 13.0°C
(no units): 0.0
Freeze Frame:
Fault Priority: 3
Reset counter: 127
Mileage: 144502 km
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0000
Hex Value: 0x0001
Voltage: 11.90 V
Temperature: 13.0°C
(no units): 0.0
