G22 Sensor/Vehicle Speed Sensor
JimmyD
Hi,
My Leon's showing a fault with the G22 Sensor and the speedo isn't working (well intermittently). Can anyone tell me what sensor it is I need to replace as I'm struggling to get a definitive answer.
I posted my full Vagcom log in the relevant section:
http://www.seatcupra.net/forums/showthread.php?p=3811490
However no one seems to know for definite. Ideally if someone can post a link to the right thing sensor to buy that would be great.
Cheers!
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
G22 is the speedometer sender (no surprise there then) which is located in the gearbox. It's in the top of the diff case, towards the back of the engine compartment.
JimmyD
Perfect, cheers.. however can you point me to a link where I can buy one? Can't find it anywhere online..
csd_19
2,280
28
Angus / Edinburgh
Check the cabling coming from the sensor on the back of the gearbox, the plug may be loose or just full of muck. :)
Will be cheaper than a new sensor ;)
james.l
GT3071r LCR
Mar 18, 2008
2,802
My House
www.vagforum.co.uk
new sensor is about £50 i broke the plastic bit on mine a couple of weeks ago and took it to the dealer for a new one as there is only 1 bolt holding it in and they said it was circa £50. I decided to glue the plastic bit back on :)
