Fuse Panel
smitty13
Hi
I have an 09 pre face lift FR - and cannot find my fuses ???
I have opened the panel near the headlight and there are no fuses there :confused::confused:
Any ideas or am I being really really dumb ??
HotHatchSteve
850
Do you mean the head light switch ? If so you are nearly there, all you do is remove the panel below the head light switch, then carefully reach up inside and push the panel on the end of the dash off to reveal the fuses.
smitty13
I found the panel that is under the headlight switch and removed that.
There are a couple of relays in there etc but mainly an empty space - no fuses or fuse panel ???? :confused:
smitty13
Cheers for the above I have found the panel I need to remove to get to the fuses - but how does it come off ??
