Fuse box on top of battery + Diagnosis light!
Ive done a search and found out how to fix the fault. Now I just need some advice on what the middle of the three fuses does? The problem started tonight were the fuse melts and the fans stop work. So I swap the buggered fuse which controls the fans with the middle of the three fuses. What does that middle fuse do?
The second problem i have is that ever since my car came out the garage last week ive had to return twice and now later today a third time because the diagnosis light keeps coming on. The first time they said the landa sesor or something wasnt connected properly. The second time they said it was something to do with the airfilter which is a H&R I think. The airfilter is sat directly behind the battery and doesnt look like its in the best postion for it, but would this cause the light to come on?? It was fine when I first got the car but since they've mess around with it this happens. I had to move the airfilter last night due to the first problem in this thread. I do have a friend with VAG COM so I could get him to have a look tonight. If I take it up to the garage at lunch and they clear the error would the error be kept in a log somewhere so I could check later?
Tom
Tom
