Full version of vag com to change ecu?
jat115
Does anyone know if the trail version of vag com supports an ecu reprogram?
As I am looking at fitting another ecu to my cupra and am not sure if my freeware/trail version can do it?
bellautos
Where abouts are you m8 ?? , may be i can help with vagcom or the IMMO in your new ecu :)
jat115
Hi,
Live in Hampshire, so quite a long way from Yorkshire iam afraid- thanks anyways.
bellautos
jat115 said:
Hi,
Nps m8
What ecu number is it ,, i may still be able to advise re the IMMO ,
There is another way if you dont have vag com :) and you get real stuck
bellautos
What i mean the ecu number is the 0281?????? number not the ecu make.
I have some trick software for immo self learn and removal that may help.
One click and its done, saves the messing in vagcom
bellautos
m0rk said:
doesn't it render the immo redundant though?
No there are 2 options in the software , 1 is recode/self learn and the other is total remaval
( realy only needed for ecu swaps on track days between car etc etc )
