fueling NOS
Mr Rob
where would the fuel feed come from for a wet NOS system on a LC? Would the fuel line be cut and a tee piece be fitted and would it be the high pressure side? Or does the fuel pump have an extra outlet?
I'm just pondering with the idea.
:drool:
daboy3000
No Longer a Seat owner
Jul 2, 2008
710
Oxted
I'm not sure mate. But what i do know is NOS is not worth the bother, used to run a MK2 Golf on it and yes it does make it go faster but the tank only lasts seconds. Its a lot of money and effort to keep filling it up. I would spend the money elsewhere.
Mr Rob
Thanks but i can get a kit for £150 and a new turbo kit will be nearer £1800. After a bit more research i think the fuel feed comes off the pressure regulator. Does this sound right? This sounds right to me as the fuel will be at a constant 3bar.
It willl only be used for track days and 1/4 mile
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
regulator is not where you would supply it..
do they mean regulated supply side? which is so the inlet pipe to the rail will be regulated
