Hi I need to replace the brake lines from front to rear. In order for me to this I need to remove fuel tank. Does anyone know how to get it completely out?. The fuel tank is loose and can be wiggled but can’t get it out. Does the rear axel need to be dropped. If so how do you get the bolt out on driver side coz fuel tank is in the way. If only the bolt was the other way round it wouldn’t be a problem. I’ve spend around 8hours on this and still no further.
Any advise is much appreciated
