Fuel cap valve
leon_geordie
Filled up with fuel at lunchtime today, and when I took the nozzel out of the tank I noticed that the metal valve at the top of the tank (the bit where you stick the nozzel through) was missing :confused:
I suspect that its got pushed down the pipe into the tank?
Does anyone know if this will be a problem? I don't want it to get stuck in the tank and cause problems.
l_g.
Fidge
SEAT Enthusiast!
Sep 9, 2004
480
Southampton UK
Shouldn't have thought it would cause you any problems! Have you got a long magnetic rod? You could use that to get it out?
leon_geordie
I have as it happens - just recently got one. Will it stick to anything else (presumably the tank is not magnetic).
l_g
