you need to take the door card off then the tweeter section just pulls off. The tweeters are held in place with plastic like weld sorta stuff. You'll need to break this to remove the tweeter then hot glue in a replacement. Replacements can be bought from seat iirc, or you can upgrade to aset of aftermarket components in which case you'll need to do the other side and the mids also.
