L280R
153
Had my front wheels off before, lcr has a standard front role bar but the colloars around it are looking very worn and the plastic looks perished. My mate has said this wont really affect performance for now but may start knocking. How much would i be looking at replace a front role bar? labour and bar?
If replacing may as well upgrade to 21-25mm and go with a rear at the same time.
About 2 hours to replace front, less than an hour fit rear bar.
Due to front subframe being dropped to access and replace bar will require a 4 wheel alignment check.
Leave until you uprate or it knocks
The cracked coating will effect the handling as the bush will not fit around the bar snugly leaving movement etc. As above better off to uprate bar when at it. R32 23mm one with all bits is £100 and makes a big difference to the handling
well my coilovers are coming nxt wk. It makes sense to get it done when at the same time but if you do front then bk has tobe done and its all about the cash!
drop links too?prone to failure on cupra and vrs variants.every MOT on my vrs had knocking drop links.
