i know theres no air getting through when its ticking over obviously , but the cooler is blocking the air flow more from even fresh air from entering from by the bumper grilles because the cooler is in the way. and in traffic sometimes the fan can cut in and drop the temp straight down again it only goes over a tiny bit after 90. It defiantly has restricted the air because it would take a long time before untill the fan came on. i think i will look into the neuspeed thermostat then.
it is quite big your right, probably the biggest i could have fitted in. i ordered two coolers one slightly smaller which i sold on here when i decided which one i was going to use. the other cooler was large aswell and would have done the job but i thought if i go down the big turbo route or anything like that its always there if needed.
The pipe work came as a kit, with 2 x 90 2 x 45 and 75 i think and 2 x straight. didnt have to use the straights. used a 45 from cooler, to a 90 then to a 75. they come in lenghts and just cut them to size, easy to cut with a good new hacksaw blade. it takes a bit of time to cut them to get them right, just cut a bit off at a time. better to take less of than too much, then join them together with the couplers and clips. mount the cooler and line everything up. get some good stong brackets from b and q
heavy duty ones. fabricate them to shape, you may have to cut tiny parts of the front panel to allow the outlets of the cooler to sit and the cooler sit level. straight forward stuff, get a good disc cutter. then primer and blow the panel over in black again. make sure the bumper will go on with some trial fits and cutting away near the foglight plastic parts on the R bumper.
pipework and cooler was from ebay, a
guide on here i followed and got the idea was from NEV LCR
guide. if you search for "FMIC TESTED" you will see the thread. cooler this size cost me £ 80. pipework £ 60, clamps etc £ 25, forge map sensor pipe £ 30 so around the £200 mark you got yourself a cooler like the forge one but for a third of the price and alloy pipework and you can say its been done yourself.
