captin_urbis
Not a Member
Dec 2, 2008
452
Lancashire
where can i get a new engine front mount from??? its not the solid metal bit im after i need the doughnut but that sits on the crossmember???
SEAT dealer and/or if you have the code written on it a VW garage.
When i got them for a golf I had they were about £60 from the dealer, as a benchmark figure.
Apart from that maybe GSF parts or Europarts?
They are designed to have a little bit of play in them, and if they are in need of replacing they usually leak as they have liquid in them.
aah right, did not no tht, will check it out, might just be a bit loose then, as when im driving the gearstick pulls forwards, indicating the engine moving forwards(i think) so showed my m8 and he said engine doughnut was ****ed.
will get a vid of what its doing,....
