vetec
while fitting the blue tooth kit i was under the dash on the drivers side and found a switch type of thing with 2 wires on it similair to a brake pedal switch but the brake lights are working fine,someone said it may be for the clutch pedal :shrug: i pressed it and didn,t seem to do anything .:think:
switch
yup the switch is white,whats it do then and would it matter its been disconnected all this time?probably since i bought it in june at least.thanks for reply ;)
clutch switch
well i hooked it back up and everything seems the same,the car still starts without pressing the clutch.the cars always drives well and pulls good ,so a little puzzled now!:confused:
switch
ok,i don,t have cruise so does that mean you could fit a cruise stalk and it would work?
switch
do you just change the stalk then?sorry to get off topic i,m kinda new to seats thats all!:redface:
