Forge MAP pipe LCR
May 13, 2007
1,017
Denmark
As forge apperantly wont answer me on the forum whether I have to use 60 or 63mm, I have to get an answer elsewhere.
So does anyone know which one to use?
harty190486
POWER!!!
Dec 29, 2008
349
staffordshire
Just depends what size pipe your using from your cooler as to what size you need mate OEM pipework is 60mm i think that was what mine war from map pipe to inlet mani
May 13, 2007
1,017
Denmark
Iirc its 63mm (2 1/2"). Give Forge a chance though, they're busy but they'll always answer.
I was giving them a chance, but when they write on the forum I should give them a call, I get a bit confused, why not just write it, so it's clear for everyone.
ThackersLCR
141
Blackpool
I wondered when id finally see a post by you!
60mm may well be OEM piping but hes got a relocation kit, internal diamiter of which is 63mm. 63mm map pipe needed. do some more research if unsure!
May 13, 2007
1,017
Denmark
Thanks for the replys, I will do some more researching to be 100% sure, I'm just a bit dissapointed that forge cant give me a 100% answer, when I actually have the relocation kit, planning on buying the race intercooler AND map pipe.
