Jan 15, 2009
595
Kent
Is it worth getting a spacer with the Forge DV? What does it actually do
Also is it easy to fit yourself? AMD want £150 for DV and then £30 for fitting it..
But its about £120.00 on the net supply only?
Hi the forge spacer just makes the woooshhhhhh noise, im not sure about fitting as i had mine fiited for me
easy to fit on the cupra engine yes, as its at the front of the engine at the top. The spacer is a waste of money if you ask me.
Its a personal taste really (kinda like marmite) you like it or hate it, there isn't a real gain in performance with a BOV all it does is make a woooooosh noise and personally I love it but yea back on the subject your car should have a OEM one stated by Carr20vt should a "Atmospheric" one very quiet. But yea its up to you what you want you can buy ones from forge where you can adjust it if you want it to woosh or shut up lol.
aka:
A wastegate is a valve that diverts exhaust gases away from the turbine wheel in a turbocharged engine system.
source
http://en.wikipedia.org/wiki/Wastegate
please correct me if am wrong thanks.
Save your money Adam, as said earlier the O/E one is just as good.
If your wanting noise - kill 2 birds with one stone and fit a good CAI
