Forge 007 - I am useless.
Vtec220
88
Fife
Guys, just tried to fit a Forge 007 to my LCR - could I get the bottom hose to go on?, could I hell[:@] - is it supposed to be that tight?:confused: - starting to wonder if I`ve been sent the wrong kit - it is just a direct replacement for the old one? - also, what is the nipple on the top of the dv for, is there meant to be a pipe on there? - anyhow, I`ve stuck the old one back on and now thinking about taking it to Star Performance. Does anyone have a photo of there engine bay so I can see how it should look?. Thanks a lot guys.
andycupra
status subject to change
it should fit the same as the stock one.
yes there should be a pipe attached to the small top one.
its the same as what was attached the the stock dv.
the bottom and side pipes should be 20-21mm internal diameter and 26-27mm outside diameter.
they take a bit of easing on but should be too difficult
cupra-c_ya
I love da boost!
Oct 4, 2004
716
devon
img124.imageshack.us
If you have got the pipes off it should be easier to get them back on, this is what I found (maybe me pipes are slack'n), maybe you had a few beers last night and you are feeling weak :cartman:
you will need a small jubilee clip for the top nipple hose, halfords matey
andycupra
cupra-c_ya said:
If you have got the pipes off it should be easier to get them back on, this is what I found, maybe you had a few beers last night and you are feeling weak :cartman:
lots of people dont have a clip for the top pipe. they dont tend to pop off.
RikH
Texas Cowboy
Oct 17, 2005
2,474
Yorkshire
ive just done mine this morning
hardest bit was getting awkward 1-use clips off, old d/v came out with a bit of yorkshire persuation
putting in new d/v was just reversal of removal, mine went easily into the bottom hose but was a fight to get into the side hose.
top hose was stiff to reconnect and is held on with 2 zip ties at the moment, they seem to be holding but ive been and got some fuel clips-going to call past chavfords tomorrow to see if i can get these clips a few have mentionned
www.leoncupra.co.uk has pics of the engine bay with d/v fitted
Reg
Professional Detailer
Oct 10, 2005
962
Berkshire
I think the top pipe is a vacuum anyway, so its sucking that pipe down onto itself. The other pipes are the ones that will come off if not properly secured.
Feel
Veedubya 'velle
Jun 12, 2003
4,918
Midlands
Yuo are fitting it in the right place aren't you? The Forge looks very similar to the stock one (except the Forge is ally, rather than plastic) - so your standard one should also have a pipe sticking out of the top.
If your standard one has a larger diameter and no pipe at the top, you're looking in the wrong place - that's a different thing altogether.
Vtec220
88
Fife
Its ok guys, managed to fit it alright - lets just say that Feel was very, very close to the mark on this one:whistle: - I feel like such a spanner:redface:. Cheers:D
Vtec220
88
Fife
bushybeaver said:
lol go on Vtec tell us what you trying to replace :lol:
Told you I was useless! - looked like it to me at the time - think its the oil breather (black, round plastic) I took off and then proceeded to lose the plot trying to get the forge to go in :censored: - what a muppet:rolleyes: :whistle: .
dobber
Hahahaa, at least its all sorted now m8. The p!$$ taking will die down after a week or so ;)
