Footwells to Windscreen?
justinking
136
deas anyone know if there is a way i could pass a wire from either the passenger or drivers footwell, up the the dashboard? im trying to hide my road angel wire, looks a bit tacky trailing all over the console..
cheers
ibiza_95
1.8T MK2 Conversion
ud probably have to drill a hole in the vents ducting to feed the wire out of there but then again the heat from the blowers may melt something.
i bet you could feed the wire if its not too thick down the side of one of the vents between the vent and the dash so it doesnt actually go into the vent?
justinking
136
yeah will have a proper look today, would prefer it coming out the middle of my windscreen where my road angel sits.. cheers for ur help mate
Ron_Cupra8v
Gold Member
Jun 16, 2005
98
Tyne & Wear
I've got a snooper and to get the power from the cigarette lighter to the dash i ran the cable behind the drivers glove box then just pushed it into the gap between the a pillar/door area and the dash with a blunt screwdriver. I've also dropped the gps antennae cable down between the dash and windscreen. no drilling required and it looks quite neat
