Fogs as DRLs
  • Thread starter Deleted member 74601
  • Start date
If I come into any money, I may buy the strips, or the foglight unit above which I believe is from the Octavia?
mrbubba
463
I'm don't know about the pre facelift, the only other thing that has to be changed is all the side lights come on as well by default.
I'll have another look at the vcds options and see if i can switch it on
Sent from my Desire HD using Tapatalk 2
splinter_cdo
308
i got pulled over about 3 weeks ago for having my fog lights on my cupra by traffic cops as i have had ppl do the same
mrbubba
463
Go for it, I've had mine done for ages (waiting for the abuse) like you said you can adjust the output, I think they are set at 72% by default.
One thing for sure, badly fitted / aligned HIDs and some none standard bulbs are way worse.
I found the option and enabled it (turned blue on vcds) and then added the code, which was accepted but it doesn't seem to work, as when I go back in the option is black again as if not set.
Sent from my GT-P7510 using Tapatalk 2
