fmic ?
cawsey18
158
hi there.
Im after a fmic for my leon fr . mk1. I know forge do one wich is 600 odd quid is there any others that do the job ? i know on the lcr there are a few that do the job . also if there was a chance of me changing the inlet maifold to a cupra r one what sort of things would need changing ?
JamJay
California Bound
Forge do the only kit that I know of. If you're not comfortable with drilling parts of your car for a custom one, then go for this. With the Forge kit, you get a new crash bar designed to hold the FMIC and as I understand, fitting the Forge kit is a case of nuts & bolts.
Aug 7, 2009
1,395
Manchester U.K
As far as i know the cupra r manifold (BAM,AMK) is diffrent to the rest of the 1.8T engines, as for the intercooler, do a search, DIY jobs have been done with good results.
cawsey18
158
ok thankyou guys .. may just save and save and go forge then probably the safest bet..
Have realised how much of a prat i was to not buy a cupra r straight out.. but hey.. my car now owes me alot so cant really go back so will just role with it buy a ko4 001 fmic and get it sort of cupra r spec.. and hey its only now done 41k !
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
plenty of tuning potential on the cupras mate.. 240bhp, sort the handling... got yourself a fast car and a bit of a sleeper aswell.
brad1
Check my thread out for custom fmic, cost me around £200 in totall and fits well, your pipework can go the same route as mine, the top pipe will just need changing route slightly ;)
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
From what I can tell you get 240-260 from a k04 001 and 230-240 from a k03s?
cawsey18
158
really ! . so your really only gettiing 20bhp extra from a ko4 when its all tuned up ? how about torque figures though ? and also adding all the little extrassports cat etc ?
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Yeah thats what I was told when I asked the other day........its a baby k04 not a proper one like the LCR
I know to go K03 hybrid you also need bigger injectors, bigger MAF, different TIP, uprated fuel pump, FMIC, bigger downpipe and manifold? and thats 270ish bhp
I'm not sure if you need all those for the k04 001 but your getting up to the same power levels arnt you so something must need uprating?
Ronin225
4,652
22
Worcester
Phillc changed his LC inlet manifold to a cupra R one and also used the standard twin intercoolers off a LCR.
It can be done and probably quite cheaply unless you want a LCR FMIC kit and inlet mani and charge pipe, etc
brad1
Heres mine, if you fancy a custom route for a third of the price of a forge kit ;)
brad1
Looks quite tidy but that lower pipe looks like it protrudes out a bit, any issues with bumper on?
Cheers mate, nope, no problems with the bumpers :) tho soon, i will eliminate that elbow hopefully and it looks like i can rotate the pipes slightly and put a straight silicone joiner in :)
cawsey18
158
nice one thank you guys . brad like the install.. looking good.. adam where did you get yours from ??
cupra_matt86
southend cruiser,not chav
May 18, 2009
102
Essex
well i have a full stage 2 parts and remap by AMD and mine is running 237BHP and 285lb/ft torque. and it is pretty damn quick now. it beat a near standard scoobie wrx sti, and pull away from uk spec scoobies, is also quicker than my mates 200sx
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
Is that a custom map or a drive in plug laptop in and drive out map?
If you don't mind me asking how much was it? :):)
