flat spot between 3000-4000 revs
abrooking_7
been ongoing for sometime now, just got it back from the garage who removed codes, but couldnt find anything wrong. drove it home and its still the same. car used to boost lovely at around 3000 revs but now has a major flat spot between 3000-4000 revs and then picks up.
wanting to fix this problem asap as im taking the car on a trip down to newquay boardmasters festival on friday
has anyone had this problem before?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
common issues:
split pipe on pcv/vacuum system around inlet manifold
tired maf
malfunctioning n75
coil packs (misfire)
you need access to vagcom (www.ross-tech.com) and some logs or find your local vag specialist
you say removed codes..
what were they?
Tucker157
1,066
Falkirk/Central Scotland
What he said above!
mine felt like it was holding back, a bit like a flat spot, I'd had it for months, wasn't untill I logged the maf I noticed it was reading 90 g/s max lol been fine since I bought a new genuine maf
But not a truer word.... Vagcom is your friend
Sent from my HTC Wildfire S using Tapatalk 2
