BlackMagicLeon
78
Hampshire
Could someone give me the part numbers for the following fixings, if indeed they have part numbers!
They are:
  • Front bumper pan-head screw (for the top of the bumper)
  • Front grille plastic 'expanding rivets'
  • Engine undertray fixing screws
Will they be the same part numbers for any VAG dealership?
Cheers!
True.. just easier if I can go pre-armed with the part numbers rather than trying to describe them over the phone - local dealer isn't that 'local'..
They are:
Cheers!
Right,
Front bumper screw - I take it this is the one that goes above the grill? If so it's a M6x16 bolt, part code N90788402
Split rivet for attaching grille to bumper - B5x5.5, part code N90536901
Engine undertray fixing screws - there's a clip, and 2 different bolts listed for this
Clip - N90533301
Panel bolt (8 per pack) - N10354602
Hex socket head bolt (3 per pack) - 1K0825951
I believe the N part codes are standard across the VAG range, and can be ordered from any VAG garage - the 1K part code is SEAT specific so can only be ordered from a SEAT garage.
Get the dealer to double-check that I've got the right part numbers as well :)
Part numbers for the entire engine undertray assembly are as follows
1K0825237J - Petrol engine BLR, BLY, BSE, BSF, BWA, BVY, BVZ, BWJ
1K0825235AB - Petrol engine BUD
1K0825237AE - Diesel engine AZV, BKC, BKD, BLS, BMM, BXE (F 1P-6-082 601)
1K0825235Q - Diesel engine AZV, BKD, BMM, BMN
If you give the dealer your chassis code he'll be able to tell which undertray you need, and from that what the right bolts/screws are for it :)
