Fitting Lambda Probes
Tallpaul
821
When fitting a new lambda probe into an exhaust, should the thread be coated with anything to help it seal/stop it seizing e.g. FireGum ?
TheOtherSimon
454
It should already have the correct coating.
You must not use anything else as there are a load of chemicals that will destroy the sensor. Silicones and copper being two of them.
Simon.
Tallpaul
821
so what about if you are not fitting a lambda probe and just putting a blanking bolt in the hole?
