fitting bypass resistors
daves ibiza
right people i bought resisitors couple off months ago did attempt them but could trust myself lol electrics. so i took them off and lost them in garage . so i went out and bought another 4 can anyone give me anytips on how to put them in ect. cut plugs off/ leave plugs on and push wires in. as i dont want to be causing any fires [:@]. many thanks guys
-pseudonymous-
681
Just cut the plugs off and solder the resistors in place. Use some heat shrink over the soldered joints to tidy it up and seal it.
kyle'87
Modding Disease
Sep 15, 2008
868
Ruislip
Cut the plug off about half way so you have enough wire to re-attach them if required.
I first soldered some wire onto the resistors to give me more options, then decided where I wanted the looms etc.
Then Put heat shrink tubing to the resitors so ended up with like a little black package with two wires sticking out and soldered onto the existing loom. Was so much easier to make it all tidy before soldering it together.
Sorted, would show you a pick but my phone cable is at home.
daves ibiza
ok thanks guys i will leave bit of wire so it can be joined if wanted to go back cheers guys:D
