If it's the MK4, then you need to undo the two screws and then apply pressure into the car at the same time as pushing the light out. Unfortunately it's a case of brute forcing it the first time. Once it's been out a few times, then it gets easier.
Theres two metal spring clips holding it in place, after removing the screws you just angle the light cluster out slightly and pull . When refitting make sure the rubber seals are in right. Theres a thread on this in Mk 4 Ibiza somewhere.
If you think thats awkward try replacing a headlight bulb
