Fitting a headunit
carlisle pete
649
im in carlisle mate not far! depending on wher in scotland! i have motorised screen mounted in the vents in middle of dash!
joonspoon
175hp. 275lbs/ft.
Nov 18, 2006
361
Oxfordshire
If your only replacing OEM with an after market unit just pull out the existing one, connect the new one and enjoy. :)
You may have to buy alternative connectors but if you bought from a good dealer they will advise.
What are you fitting?
Guy.
carlisle pete
649
dont work like that in mk3's mate! ther standard headunit is built into the climate control etc! so u need that to work to! and u cnt take it out so u hav to find alternative place to put one thats y mine is fitted into the dash
C3 LJG
Serial Speeder
Dec 23, 2003
807
Chandlers Ford
www.cardomain.com
I have mine mounted under the steering wheel in the space by the fuses, out the way and works off a remote control, maintains the standard look when you look throught the window so keeps the little sh1ts away!
beattie17
1,353
Perth
Awrite you got any pic's of your's? You do it all yourself? im based in perth not too worried about travelling to get it done.
