fitting a boost gauge to my lcr
oxo
hi there can any body help me out im trying to fit a boost gauge to my seat leon cupra r 225 and im not to sure with pipe i use ie; the boost line if anyone no's i'd be graetfully of the info a photo would be even better thanks:confused:
D.K
LCR 225
Oct 24, 2007
6,408
se london
Take the vacuum feed of the FPR (Fuel Pressure Regulator) Dont take it off the D/V
Feed it around the airbox and into the wireing loom box that goes into the pollen filter housing ( follow thr red cable in my picture)
Remove the pollen filter, behind the filter you will find a gromit
Push the pipe through here.
Now remove the glove box and route the pipe under the dash to where you want the guage
I took the electrical feed off the radio but you can cut into the fuse box on the side of the dash on the drivers side.
D.K
LCR 225
Oct 24, 2007
6,408
se london
If your going to run an amp it might be wort running the cable for this at the same time to save takeing the glove box out again.
oxo
thanks mate thats brilliant thanks for the pic.
:happy:
oxo
hi there dose any one no what bar my lcr 225 bhp should run standard on my boost gauge caus took the feed from off a pipe that comes off the the cluster off pipe witch the d/v feeds to and gose to the inlet and not from the fpr cause was shown by a friend but i have also be told to use straite off the d/v or off the fpr .. many thanks
mike&emzbakes
Fitted my boost gauge today was worried about doing it but easier that I thought it was going to be, I run it off the fpr and works fine wired into lights only connected live and earth cables found connecting orange cable dimmed my gauge lighting a little but it working good without it
markpile
Wolves till i die!!!!
Mar 15, 2014
434
Wolverhampton
Fitted mine on my lc to the vacuum on the dv, all my other turbo cars I've ran it from the dv on my lc I'm getting a reading of 1.1 bar what's the reason to use the for and not the dv???
doodle86
west mids
I haven't got the answer myself but it's a good question as my mate said the same thing to me the other day... Apparently you don't get the real reading off the top of the dv :-/ I'm running mine off the top of the dv an gettin 10psi holding at 9 I'm guessin the reading can't be that far out
markpile
Mar 15, 2014
434
Wolverhampton
I have done the n249 bypass so my dv is now run off the manifold as is the fpr but took gauge out as it just didn't look right and now use the torque app
Sent from my C6603 using Tapatalk
markpile
Mar 15, 2014
434
Wolverhampton
Not much just less pipework for things to go wrong and leaks I think it's ment to give a better Control over the dv
