Well after speaking to lots of you at Oulton I decided I needed VAG-COM.
Tried to do some logging tonight and got the figures below. I only did block 002 and group 005 (I know they shouldn't really be done at the same time now) also didn't do 115 and 118. Just wanted mass flow to start with...
Group A: '002
RPM Loa Inj. On Time Mass Flow
TIME
STAMP /min % ms g/s
0.39 2360 42.9 3.74 19 Part Throttle
1.3 2360 47.4 4.08 21.11 Part Throttle
2.3 2360 57.9 5.44 28.25 Part Throttle
3.2 2400 48.9 4.08 19.67 Part Throttle
4.11 2400 47.4 4.08 20.81 Part Throttle
5.12 2400 47.4 4.08 21.39 Part Throttle
6.13 2440 56.4 4.76 26.19 Part Throttle
7.03 2480 56.4 4.76 25.81 Part Throttle
7.94 2520 65.4 5.44 33.44 Enrich.
8.94 2640 112.8 10.54 65.72 Part Throttle
9.85 2920 143.6 13.6 78 Part Throttle
10.85 3160 140.6 12.92 86.31 Part Throttle
11.76 3440 141.4 13.26 93.14 Part Throttle
12.66 3720 143.6 13.6 102.28 Part Throttle
13.67 4000 141.4 13.6 107.58 Part Throttle
14.57 4240 142.9 14.28 114.81 Part Throttle
15.58 4480 141.4 13.94 122.03 Part Throttle
16.49 4720 138.3 13.94 125.47 Part Throttle
17.39 4920 143.6 14.28 134.31 Part Throttle
18.29 5160 145.1 14.62 140.86 Part Throttle
19.2 5360 145.9 14.28 150.39 Part Throttle
20.11 5560 145.9 14.62 155.75 Part Throttle
21.01 5760 145.9 14.62 159.78 Part Throttle
22.03 5960 141.4 14.62 160.56 Part Throttle
23.02 6120 135.3 13.26 159.19 Part Throttle
23.93 6240 139.8 13.94 161.64 Part Throttle
24.94 6400 131.6 12.92 161.08 Part Throttle
25.85 6560 68.4 5.1 100.64 Enrich.
Does the above look ok? 160 g/s seems to be about normal for a stock 210 LCR? The throttle bit seems weird as it was mashed to the floor (4th gear 2000-6500rpm) run or is it always like that?
I got the below at the end of a second shorter blast:
6400 133.8 13.94 165.75
I am also trying to diagnose a bit of hesitancy which occurs intermittantly between 2-3k (in varying places) since I had a Revo trial but you might know it didn't do it tonight.
Would the 115 and 118 blocks be better for that?
Also are you guys mainly using registered versions? I'm using 409 with the lead I have but it dosen't seem to want to do the full fault code scan without complaing about not being a full version.
Any help / advice would be greatly appreciated. I couldn't decide if this should be in here or the Leon board.
Group A: '002
TIME
STAMP /min % ms g/s
