finishing touches.
Eddy Gein
70
Hi all, iv nearly got my leon fr the way I want it now, got the sound system and head unit in, the bodykit on, 19" wheels and lowerd eibach and koni suspension now i just want the rear wheels to sit more towards the edge of the arch using some spacers.
Can I use the spacers designed for a mk5 golf and if so does anyone now which make to go for?
Thanks.
MatG
114
www.astraownersclub.com
eibach do spacers for the vag group. Give your prefered eibach supplier a call and they will be able to sort you out. I think you can get them 5mm 10mm and 15mm. Dont forget to budget for some longer wheel bolts as well :)
Mark 5 ones should fit as long as the PCD and the hub size is the same - an eibach dealer should be able to help you though (but I am sure some one on here will quailfy that as well :)
