Fiat Coupe Discs on Brembo's??
coxyboy
Ibiza Cupra R
Aug 16, 2008
191
W-S-M
hi have been looking for uprated grooved discs for my Cupra R but everyone lists 280mm x 22mm for them! no one seems to know there 305mm x 28mm, but have since found that a fiat coupe has 305mm x 28mm 4 stud discs so if i was to buy coupe disc would they be a straight swap??
cheers
coxyboy
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
A quick look at the 'similar threads' link down the bottom suggests you didn't think "maybe I should have searched first"
coxyboy
Ibiza Cupra R
Aug 16, 2008
191
W-S-M
haver checked all the threads but no answer! no one said any fit for sure!
does any one no of any other cars that have 305mm x 28mm with 4 x 100pcd 57mm bore cause really fancy some brembo max discs! and they only list 280mm x 22mm for Cupra R :shrug: ??
cheers
WeeJase
pert
Jun 2, 2001
8,595
speak to one of the many site sponsors,they will all be able to put a hand on the right ones for the cupra R
i know badger5 will be able to give you an informed answer and a decnt quote no doubt.
coxyboy
Ibiza Cupra R
Aug 16, 2008
191
W-S-M
have spoke to badger5 but was just seeing what else was around as dont want to be limited to 1 type!
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
The only brake discs that fit an ICR are ICR brake discs.
Fiat are the wrong PCD, wrong centre bore & I think the wrong offset
coxyboy
Ibiza Cupra R
Aug 16, 2008
191
W-S-M
k that sorts that then lol :D
cheers was worth ago! looks like ill prob go for badger5 1's then
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
the disks will be std seat ones, grooved (lots)
same as i do but i prefer the quieter less aggressive elipticallyt grooves personally.
