Fiat coupe 20v Turbo, 304mmx28mm 4x100 brakes discs
JKing
Cupra-R
Aug 9, 2003
598
Mansfield, Notts
photobucket.com
Does anyone know if Fiat Coupe 20v Turbo brake discs will fit my brembo equipped cupra-r??
The Fiat also uses brembo callipers and the discs are 304mmx28mm 4x100 so would have thought they'd fit straight on??
My discs are on paper exactly the same but 305mm which shouldnt make any difference. The fiat discs are much more readily available and therefore cheaper.
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
Be intresting to find out if they do fit, would certainly be good to get cheaper, keep us posted if you decide to go for it
_AJ
Ex - Ibiza Cupra
Apr 11, 2006
73
Essex
interesting..... cheers fella.
Don't suppose you or anyone knows a rough price at how much these 'carriers' would be???
Harry's cupra
What to do
Oct 8, 2005
163
Yeovil Somerset
Little while back i'm pretty sure someone was seeling on ebay some brembos off a Fiat Coupe that had been adapted to fit on mk2 golf hubs, think they have just had to machine a little bit off the carrier which is part of the caliper on the Fiat Coupe Brembos.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
fiat 20v coupe disk:
Part No: D941
Front Discs (Pair) Details
Standard Discs
"British Made" Premium Quality Replacment Brake Discs.
List Price: £160.68
Price: £144.61 (£169.92 Inc. VAT)
Whats unknown is offset, hub spigot size and confirmed pcd
OE disks are ~£60each +vat
joshpmc
Cupra R Power
Jul 29, 2008
111
Manchester
I would be interested to find this out. My brother has a set of fiat coupe brembos lying around in our gaarge as hes planning on putting them on his punto gt3, I may have to spend a day playing about to see if they will fit mine.
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
disc wise fiat coupe EBC D941 >Xref> QH BDC4675
studs : 4 (no pcd)
outer diam : 305mm
max thickness : 28mm
min thickness : 27mm (seems harsh lol)
overall height : 44.7mm
centre bore : 59mm
if that helps but not got spec listing info for the SEAT ones
alt: QH BDC4739 (peugeot 406 coupe) also Brembo
studs : 4 (no pcd :()
outer diam : 305mm
min thickness : 26mm
overall height : 28.2mm
centre bore : 66mm
from picture memory the pug discs are close if correct at all as the seat ones were pretty flat iirc ??
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
overall height is the key one - looks like different offsets as well as wrong pcd.
Disks are £57 each plus vat for ibiza-R ones
joshpmc
Cupra R Power
Jul 29, 2008
111
Manchester
So bill you dont think its possible then??? My brother said we can try the calipers next weekend and see how far out they are and what work/ modification it involves!
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
if you have em lying around and have the oppertunity to try, I definately would.
even if its just to be able to tell us for certain that it doesn't fit.
