Few Running issues AAARRRRGGGHHH
valley
104
Hello all,
Just searching for a little help if possible.
I havent had my leon too long and have just started to experience a couple of running issues.
Idle: firstly with my idle, it will sit below 1k as it should but will dip down to around 600 and shoot back up again. Like it has a heart beat.
Cutting out: On a couple of occasions I have pulled up to roundabouts and traffic lights and as soon as I dip the clutch the car will cut out. :( this has happened on a couple of fresh runs.
My friend has a diagnostic machine and it came up with a couple of codes. If i remember correctly they are 17705 and 17745 (i think)
What should i do to resolve the issue??
Thank you very much in advance
Josh
adm013
197
Edinburgh
17745/P1337/004919 - Camshaft Position Sensor (G40)
17745/P1337/004919 - Camshaft Position Sensor (G40): Short to Ground
Possible Symptoms
* Malfunction Indicator Lamp (MIL) active
Possible Causes
* Camshaft Position Sensor (G40) faulty
* Wiring/Connectors from/to Camshaft Position Sensor (G40) faulty
Possible Solutions
* Check Camshaft Adjustment
* Check Camshaft Position Sensor (G40)
* Check Wiring/Connectors from/to Camshaft Position Sensor (G40)
17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Possible Symptoms
* Power Loss
Possible Causes
* Leaking hoses and/or pipes between components
* Check Boost Pressure Control Valve (N249)
Possible Solutions
* Check hoses and/or pipes between components
* Check / Replace Boost Pressure Control Valve (N249)
* Check / clean Throttle Valve, do Throttle Body Alignment
Special Notes
* Did anyone fitted an extra (wrong) dump valve?
http://wiki.ross-tech.com/index.php/Main_Page
Above is a great website for codes etc...
Andy
valley
104
Thank you mate, Ill check it out. Im not the mechanical minded kind of person so hopefully my mate will know.
Thanks again
