few little problems with new ibiza
onvi-cupra
62
right i have just bought a 2000 ibiza cupra and have a few little niggly problems have done a few searchs and found some stuff just need a little more info.
1. need to find out what the problem is with my windows, if u press the passenger side switch it goes down then goes up on its own, the drivers side doesnt work at all any way to test wats broken?
2.were can i get injector seals as my injectors are leaking?
3.wat is the purpose of doin the n249 bypass?
also went to amd's in thurrock to get a diagnostics this is the result:
vac lines to n249 valve split
egr pipes split
injector leaking
ambient air sensor fault
can anyone shed any light on these? thank you in advance neil
May 25, 2008
2,400
cambs
the n249 bypass just bypasses a few useless solinoids(pardon the spelling ) easy fix , injector seals you can either get them from the stealers or most motor factors should be able to source them for you, egr pipes like above really just replace them or do the sai removal (like me and fit a catch can )there is various guides on here how to, the ambient sensor is located i think in the passenger mirror another quick and easy fix part available from either the stealers or the motorfactors ,sorry for the rant!
onvi-cupra
62
Anyone In Essex willing to come give me a hand as I can't seem to wrap my head round the guides?
venner
Drives Ibiza Cupra T
Apr 21, 2009
197
Near Bristol
I had this when i bought my cupra, i solved it by spraying WD40 into the button and it cleared the contacts and i havent had the problem since.
