nickmk1
Hey guys,
On top of the engine on an ayp cupra, either side of the 06a 131 051 f box, two solenoid looking things which is which, both seem to have the same part number, one has a turny twisted black end where the other has an outlet.
On the oil filter housing you have two outlets for coolant, one pointed away from gearbox and one the other way, where do they go as i seem to be missing the hose for them (dont worry its an engine ive bought, not driving around on it...) also on a rail coming round the gearbox side of the engine missing two hoses which then go up to feed the heater matrix?
Ideally i want as little as possible in terms of vac/boost spurs, i would need a dump/recirc, boost solenoid, a tee off into a boost meter and obviously routing from turbo to intercooler and into inlet. I will be running megasquirt so it leaves me free to have these in the best positions, ive heard possibly for the dump/recirc it needs to be close to the inlet any suggestions for the other bits or diagrams!!
Cheers, realise its alot but anything answered would be appreciated.
Nick
Nick
