FEELER: Single guage in centre console
wilksy
tfsi
Aug 13, 2005
304
oxford
would that mean i am the odd 1 out wantin the black back n red digits as my cupra is my01 so thats wot my dials are.
which obviously why im happy with the gauge in the link i posted in #58 as dodson said psi would be better
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
I mean i could make one without the gauge fitted in it, and you can source one... as i said, mojority of people asking for the guages are from the my03 range and have white dials.
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Not far or disimilar from this....
(quick photochop of a likely design...the back will be bright white, just only found a illumated pic )
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Looks good, aside from the FR logo, as that should be the LCR 'R' ;)
Again something that i can make up... FR...R...Leon....SEAT... whatever someone wants it could be changed too hopefuly, all down to weather i can get the printing on the faces done easily...
wilksy
tfsi
Aug 13, 2005
304
oxford
like the design would it be much of a job to put the gauge in?
cos if i am the odd ball then a fabricated dash will suit me cos thats the bit i feel i cant do.
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Erm... to fit a gauge, remove from packaging and push in prefabricated hole in custom dash... DONE.. [B)]
The hardest part is the vacum line... in the custom ones, I'm thinking of having a section of hose plumbed in already into the console and then you basically plug the guage in from there, then just find the route to the T point in the engine bay.
slick
Bit of an animal
Mar 15, 2005
1,124
Essex
Dodson yes it is on top of the DV on a petrol, but on a diesel you have to T into the intercooler charge pipe itself.... not got it easy like you petrol heads.. lol
And I'll get on to it soon mate... sort the guages first, there the fiddly bits...
wilksy
tfsi
Aug 13, 2005
304
oxford
been searchin all evenin cant seem to find anything exactly like mine
i found a tt engine bay n dv but not a leon 180bhp
Dodson
Extreme Blue
Feb 9, 2005
610
Redcar
On the top of the DV there is an outlet that you connect a small, vacuum type cable into, my understanding is, you put a T piece onto that, connect the existing vacuum wire to one side of the T piece and your DV vacuum cable (that you will have to route yourself) to the other side of the T.
wilksy
tfsi
Aug 13, 2005
304
oxford
got a better understandin now! so u actually have to insert a t piece rather than look for a t point.
the other reason i found this important is i may invest in this new fordge split r valve specially designed for the 1.8t and wanted to make sure i chose the right item to change
wilksy
tfsi
Aug 13, 2005
304
oxford
ok nice 1 ill look forward to hearin updates on fabricated dash's!
i see the situation as ill source the gauge i found and order it once a dash is availble.
wilksy
tfsi
Aug 13, 2005
304
oxford
finally found a guide to fit a boost gauge the trouble is its for an a pillar install.
i was just wonderin where u would feed the vacuum hose on the dash install?
Rikko
Owner Of The Possesed 1
Dec 19, 2006
214
Grimsby
Now guys this gauge thing sound good im trying to source a dash for my LCR so i can have this mod done. But what intrests me most at the mo is the gauge face with the FR logo on are these the original faces with it stuck on or you had aftermarket ones made. As i think it adds that std look to thwm when fitted and would look good with the R in for all them LCR owners. What would you charge for me to send you the dash work your magic then send it back no gauge required as have my own cheers.
Rikko
