Faulty door lock
Muzorewa
¡Muchas gracias señores!
Aug 6, 2003
779
Manchester
Did a search for this and couldn't find anything, the wife's Ibiza had a problem a year or so back where the key got stuck in the driver's door, didn't operate the locks and couldn't be removed. Bit of a bind, had to drive round for a few days with a key stuck in the door while Seat got new locks ordered. Wasn't too bad, car was still secure and you could operate the central locking from the passenger door, just a bit of a bind.
Now it's happened again, the local (non-Seat) garage says it's common on Ibizas.
Is it?
And is it easy to fix without going to a Seat main dealer. :blink:
alimac81
Victory is mine!
Nov 20, 2002
306
yup got the same problem, same day my engine went my drivers side door lock stopped working, key goes in but feels like the mechanisum has sheered or something :shrug:
markarse
66
The gf's polo had exactly the same problem.
It's so common that VAG even do a repair kit to fix it apparently.
My tame mechanic fixed it without to much hassle, but he said that it was a pain in the @rse to do (i.e. fiddly).
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
Moved to the DarkSide
when i bought my mk2 the drivers lock just 'spun' in the handle.. changed it over to the pasenger side.. but noticed a part had sheared. so off down the scrappy,, gor replacement bits .. (kept same barrel).. cost couple quid.. 20 mins work, tops!
devilifrit
mine did that and was snowing heavy at the time looked like a snowman when i got the key out lol
MiSeaTGti
i have the same problem... the lock feels likes its sheared.. was wondering how to fix this...
how to take the lock/ door apart etc... to replace the part i need??
any assistance would be great..
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
open door.. remove rubber grommet on leading edge.. theres also few 'tor-x' type screw heads to be undone.. youll also need to remove the inner door-liner panel..handle comes out....(watch you dont lose spring when you take it off;).. bits are easily interchangeable... refit in reverse sequence...
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
washed me car and on one cold nite couldnt turn the lock
10 mins later couldnt get the key out at all :censored:
after some pratting around with a lighter all ok
everytime i wash it now first thing i do after is grease up the barrels :happy:
MiSeaTGti
Hey Brummy... done what you said... ive noticed a few cracked bits of aliminium within the doorhandle near the bigger spring..that holds the rod that connects to the main part of the lock... that turns with the barrel...that holds all these things into place...
Was wondering if this was the same problem you had?? if so what do i ask for... or should i take it to a dealer... or should i go to the wreckers..?? and should i get the whole handle wif all the extras attached??
if it wasnt the same prob ?? wat was your prob..?
Muzorewa
Aug 6, 2003
779
Manchester
The first time this happened to Mrs Muzorewa's car she took it to a friendly Seat dealership and was charged about £500.00 to remove stuck key, strip doors, sort locks etc. That was a couple of years ago.
Now with the same problem she engaged a mobile locksmith who removed the lock WITHOUT stripping the inner door panel, switched the driver & passenger door bits (so the passenger door now doesn't work on the key) and sorted it for £38.00.
These are the damaged bits: Knackered bits which are available from your Seat or VW parts department for buttons. ;)
Brummy
Nazi Moderator-Bot
Mar 6, 2005
4,275
i got mine from a scrapyard.. luckily had a mk2 ibiza in, but the locks are much the same as a mk3 polo etc.. gonna pop down a few scrappies soon to see if i can get a mk3 polo rear door handle to enable me to theoritally 'de-lock' the passenger door anyway.....
