faults found .. help please!
Georgie
WADDA YA WANT.. EH?!
Nov 27, 2005
451
FLEET
not mine before you think i am hurting my car again!!!
VAG-COM Version: Release 303.1
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 06A 906 032 RP
Component: 1.8I R4/5VT 0010
Coding: 11500
Shop #: WSC 78391
SEZ7Z0D2660288
1 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
Readiness: 0010 1100
Address 03 -------------------------------------------------------
Controller:
1 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 B
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
0 Faults Found:
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 16396
Shop #: WSC 06402
1 Faults Found:
49-10 - No Communications - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6LL 920 920 A
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 00441
Shop #: WSC 00000
VSSZZZ6LZ5R035994 SEZ7Z0D2660288
0 Faults Found:
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 0062 GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 06402
1 Faults Found:
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10121
Shop #: WSC 06402
1 Faults Found:
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: JS Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
1 Faults Found:
01134 - Alarm Horn (H12)
37-00 - Faulty
Address 56 -------------------------------------------------------
Controller: 6L0 035 156 B
Component: seat s04 GRO 3 99
Coding: 00401
Shop #: WSC 06402
0 Faults Found:
End -------------------------------------------------------
but with this.. the airbag light in the dash is on.. . but i refuse to do a check on the airbags.. cause knowing my luck they will go off and i will stain his seats brown.
thoughts.
its a 05 plate ibiza cupra 20VT
Uwe@Ross-Tech
392
www.Ross-Tech.com
Since all those communications codes are "Intermittent" I would clear them and see how quick they come back -- if they do at all.
Was the car chipped recently? If so, there are people out there who *still* don't know how to get around the "firewall" in the instrument cluster except by pulling the fuse for the cluster. And if someone did that, it would explain those cimmunications codes. But if this is the case, they should have cleared those codes afterward.
-Uwe-
gazjones
i had these sorts of things on mine and it was down to batery being disconected but dealer cleard them and they never came back!
Georgie
Nov 27, 2005
451
FLEET
erm yus. i will clear the codes tomorrow for him then, car is remapped. but tis a revo stage 2 and has not had problems with that.
and very sure the battery wasnt disconected or run down.
