hi
just scanned the car after recieving delivery of my cable and i've got 2 faults
17704 P1296 Cooling system malfunction
18010 P1602 Power Supply (B+) Terminal 30 Low Voltage
these are codes i've looked up on the forum,
Vag Com actually says this:
17704 - Error in Mapped Cooling System (usually temp Sensor or Thermostat)
P1296 - 35-10 - - - Intermittent
The intermittent bit doesn't sound to bad, but how intermittent is it? could this error happened once or twice and never happened since? is there a way of finding out?
anyway i'm a newbie at all this so any advice appreciated in sort it
Mark
full output below
VAG-COM Version: Release 409.1-US
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01: Engine
Controller: 1ML 906 032
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 00000
VSSZZZ1MZ3R112825 SEZ7Z0C1915413
2 Faults Found:
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 06441
No fault code found.
Mark
full output below
Address 01: Engine
Coding: 10510
Shop #: WSC 00000
2 Faults Found:
Coding: 0019469
Shop #: WSC 06441
