Logged on my brothers mk4 2.0 golf gti;
Sunday,12,February,2006,12:31:24
VAG-COM Version: Release 512.1-UD
Control Module Part Number: 06A 906 018 GM
Component and/or Version: 2.0l R4/2V MOTR HS V03
Software Coding: 00031
Work Shop Code: WSC 00028
3 Faults Found:
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
16555 - Fuel Trim; Bank 1: System Too Lean
P0171 - 35-00 - -
Sunday,05,March,2006,16:01:23
3 Faults Found:
16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
P0131 - 35-00 - -
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
The garage has replaced a lambda sensor but i believe there is two,do you think they replaced the wrong one?
Also logging block 30,
sensor 1 is at 100 and sensor 2 is 110,apparently they should read 111.
3 Faults Found:
P1128 - 35-00 - -
P0171 - 35-00 - -
3 Faults Found:
P0131 - 35-00 - -
