Fault codes?
UltraObamaX
72
Stafford, UK
Hi all,
I have done a full scan using Car Scanner ELM OBD2 from the play store and have a load of stuff that I don't understand. Anyone here able to decipher this? Car is a Leon CR170 2009 CEGA if that helps.
============1==============
P242A
Raw code: 242A
ECU: Engine control unit
Status: Pending
OBDII: Exhaust gas temperature sensor 3, bank 1 - circuit malfunction
============2==============
1316
Raw code: 0524
ECU: 19. CAN Gateway
Status: Test conditions are met, Validated and stored in non volatile memory
Seat: Brake control unit
============3==============
13701392
Raw code: D11110
ECU: 08. Heater and climate[Archive (inactive)]
Status: Confirmed
============4==============
1316
Raw code: 0524
ECU: 15. SRS
============5==============
12656896
Raw code: C12100
ECU: 17. Dashboard[Archive (inactive)]
Status: Confirmed
Seat: C11F0F0: Static calibration (end of assembly line)
active
============6==============
66048
Raw code: 010200
ECU: 42. Driver door electronic equipment[Archive (inactive)]
Status: Confirmed
Seat: U113B00: Rain/light recognition sensor
implausible message
Seat: C100700: Brake disc right rear not reached
Seat Toledo 2009-2015, Altea 2009 - 2015, Altea XL / Freetrack 2009 - 2015, Leon 2009 - 2015; Alhambra 2011-2018: B11EC54: Motor for front window regulator
No basic setting
============7==============
1316
Raw code: 0524
ECU: 44. Power steering
Status: Pending fault present, Test conditions are met, Test is inhibited by other DTC, Validated and stored in non volatile memory
============8==============
132610
Raw code: 020602
ECU: 52. Front passenger door electronics
Status: Test failed, Confirmed
Seat: B122C01: Central locking motors, rear
Electrical error
============9==============
0001
Raw code: 0001
ECU: 56. Head unit (MMI) (VW TP2.0)
Seat Toledo 2013 - 2018; Alhambra 2011-2018; Mii 2012-2018: C101A14: Left front ABS wheel speed sensor
Open circuit/short circuit to ground
Seat Ibiza GP2 2016-2017; Toledo 2009-2015, Altea 2009 - 2015, Altea XL / Freetrack 2009 - 2015, Leon 2009 - 2015; Alhambra 2011-2018; Mii 2012-2018: U12C800: MAC address conflict in Ethernet switch branch 1
Seat Ibiza GP2 2016-2017; Toledo 2009-2015, Altea 2009 - 2015, Altea XL / Freetrack 2009 - 2015, Leon 2009 - 2015; Alhambra 2011-2018; Mii 2012-2018: U14FD00: Secure Onboard Communication
Time server not available
Seat Toledo 2013 - 2018; Ibiza GP2 2016-2017; Ibiza 2017 - 2018; Toledo 2009-2015, Altea 2009 - 2015, Altea XL / Freetrack 2009 - 2015, Leon 2009 - 2015; Alhambra 2011-2018; Ateca 2016-2018, Leon NF 2013 - 2018; 5F - A-CUV , 5F - Leon; Mii 2012-2018: B1A7000: Updateprogrammierung fehlgeschlagen
Seat Ibiza GP2 2016-2017; Toledo 2009-2015, Altea 2009 - 2015, Altea XL / Freetrack 2009 - 2015, Leon 2009 - 2015; Alhambra 2011-2018; Mii 2012-2018: B18B0F0: VKMS
Missing adaptation
Seat: B108F07: Temperature flap motor
mechanical malfunction
Seat Toledo 2013 - 2018; Ibiza GP2 2016-2017; Ibiza 2017 - 2018: C1069F0: Control difference
exceeded
Seat Toledo 2013 - 2018; Ibiza GP2 2016-2017; Ibiza 2017 - 2018; Alhambra 2011-2018; Ateca 2016-2018, Leon NF 2013 - 2018; 5F - A-CUV , 5F - Leon; Mii 2012-2018: B111913: Antenna 1 for radio
Open circuit
Seat: B17A111: Connection between control module and antenna amplifier
Short circuit to Ground (GND)
Seat: C007500: Brake Pedal Position Performance
Seat: B108C22: Left temperature flap positioning motor
Upper limit exceeded
Seat: C110115: Windshield heater for directional stabilization assistance
Open circuit/short circuit to B
Seat Toledo 2013 - 2018; Ibiza GP2 2016-2017; Toledo 2009-2015, Altea 2009 - 2015, Altea XL / Freetrack 2009 - 2015, Leon 2009 - 2015; Alhambra 2011-2018; Mii 2012-2018: U303600: Communication Authentication Signal Performance
