OK our Vario has started to have a couple of problems, went to it about 2 weeks ago and it wouldn't pull very well and but the time I got home (15 mile jouney) I didn't think we would has it had no power at all and just limped back.
Anyway I thought it was fuel filter so I gave it a service, started it and still the same problem, so as I have a tunning box fitted I removed this and all seemed well. To prove it was this at faulty I reconnected it and car still drive and pulled fine.
Anyway I have done about 500miles since then and then again yesterday she started to play up again, when I started her from cold she as hunting very bad, so again I removed the tunning box and when for a drive, this stopped the hunting but she had no or very little power under 2.2k and then you could feel the turbo coming in. parked her up for 20 mins came out and since then all has been well.
I have just put VAG-com on and got these fault codes, now I know the EGR one as it has been removed but anybody got any ideas on the others?
many thanks as always.
VAG-COM Version: Release 311.2-N
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 028 906 021 DK
Component: 1.9l R4 EDC G00SG 0827
Coding: 00002
Shop #: WSC 06406
4 Faults Found:
01265 - Exhaust Gas Recirculation Valve (N18)
31-10 - Open or Short to Ground - Intermittent
00765 - Modulating Piston Movement Sensor (G149)
35-10 - - - Intermittent
01268 - Quantity Adjuster (N146)
18-10 - Upper Limit - Intermittent
19-10 - Lower Limit - Intermittent
Readiness: N/A
Skipping Address 15-Airbags
Address 25 -------------------------------------------------------
Controller: 6H0 953 257 A
Component: IMMO VWZ3Z0W9190101 V68
Coding: 09600
Shop #: WSC 00000
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
End -------------------------------------------------------
Coding: 00002
Shop #: WSC 06406
4 Faults Found:
Readiness: N/A
Coding: 09600
Shop #: WSC 00000
No Faults Found
