Fault codes
rickisgrate
No idea how a turbo works
Oct 4, 2007
129
ayrshire
gotta mate to plug vag-com in last night and it flashed the following. Its gotta green induction kit so if anyone can help it would be much appreciated
Address 01: Engine
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 00000
4 Faults Found:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
17968 - Maximum Engine Speed Exceeded (Engine Warranty VOID! :)
P1560 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
ignore the engine speed one its the remap but not sure of the other 3
sureal
17964/P1556 - Charge Pressure Control: Negative Deviation
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too Low
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
sureal
16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
Possible Solutions
Check Fuel Pump Relay (J17)
Check Secondary Air Injection Pump (V101)
Check Secondary Air Injection Pump Relay (J299)
Check Secondary Air Injection Solenoid Valve (N112)
Retrieved from "http://wiki.ross-tech.com/index.php/16795/P0411/001041"
This injects air to exhaust system to bring cat up to temp quicker when starting from cold
sureal
Means your a loon behind the wheel having fun:p
check out the link to the wiki site its got loads of info.
sureal
so nothing serious then, im sure its nothing you cant put right eh
Nothing a couple of trolley jacks cant fix mate;)
Especially at the side of the road on a bypass (somebody ask him why he needed a trolley jack on that particular occasion see if he answers)
Cupra_G
185bhp/230ftlb
Mar 7, 2006
172
ayrshire
s62.photobucket.com
Hey ricki how does the car drive?? I'm sure strapper had the same codes (I'll need to check with him), his car felt like there was no turbo, the car didn't boost!! Turned out the nut came off the wastegate!:lol:
rickisgrate
Oct 4, 2007
129
ayrshire
still drives fine, sometimes holds back a bit but very rarely, ive that a few times when it feels as if the turbo feels as if its fell off just just turn it off then back on again and it goes alright
