Fault codes
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
Got some re-accuring fault codes, the have been cleared before and keep coming back every time. Thinking there is an alternator fault but would like some more info if any of u lot can help it would be much appreciated. Results are below:
Address 01: Engine
Controller: 038 906 019 HQ
Component: 1,9l R4 EDC 0000SG 1502
Coding: 00002
Shop #: WSC 06402
VSSZZZ6LZ2R011893 SEZ7Z0A1193827
1 Fault Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
Address 08: Auto HVAC
Controller: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
000 - - - Intermittent
Address 09: Cent. Elect.
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
00907 - Intervention load Management
35-00 - -
longman
Stumped!
Mar 13, 2007
613
Nr Maidstone, Kent
Hi Mate
17911 is to do with the regulator on the alternator or wiring from it. Its worth checking the charge you are getting back to the battory incase its overcharging.
01272 means there is a problem with the direction flap on your HVAC. There may be something obscuring it or it may be broken or blocked meaning the servo moving it cannot operate properly.
00907 is interesting!!: http://wiki.ross-tech.com/index.php/00907
Guinness
Finally got the BMW
Nov 29, 2006
4,422
Newcastle
ah the last one could be because I got a flat battery the other day (had 2 leave hazards on behind an accident for 2 hours). Needed a bump start lol.
Chears matey appreciate it, will look into the above.
