fault codes since changing the thermostat housing
boltonredgt
147
Bolton
I have fault codes and an issue with the second fuel injectors since I changed the thermostat housing on my 2014 Cupra SC. these are the codes
16452 implausible data received from control module
15434 cyl 1 inj2 no voltage
15435 cyl 2 inj 2 no voltage
15436 cyl 3 inj 2 no voltage
15437 cyl4 inj 2 no voltage
When it is cold it starts and runs until the engine warms up then there is a stutter and the ESP light comes on and it runs as normal with no performance issues.
When it is warm it will not idle on start up unless you rev it until the ESP light comes on then its back to normal performance. I have ( I think ) reset the throttle position using my VCDS but dont know if it has taken. Is there a different technic to reset the throttle on this model? Anybody else had this issue or know how to resolve it?
