fault codes please help
PAUL HEV
Bananna Bomber!!
Sep 30, 2006
117
grasmere cumbria
just ran a vag com test and found these faults!
16486 Mass or Volume Air Flow Circuit - Low input A
16524 O2 Sensor Circuit - Slow Response (Bank 1 Sensor 2) B
17748 Camshaft/Crankshaft Position Sensors (B2) - Out of Sequence A
18010 Power Supply (B+) Terminal 30 - Low Voltage D
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
could some one please shed some light on what these exactly are!
i am guessing 3 are to do with a knackerd lamba sensor!
courtney gray
one of my lamba sensor is not doing its
job propoerly when i pluged it in to my vag com it said its the one before the cat could that make me loose power and burn fuel
