I have carried out a fault scan on the Car Seat Altea 2005 TDI. I have used the VCDS 11.11.3 software. I'm not sure what all these fault mean, but the car is losing power at around 2500 rpm's. keeps going into the limp Mode.
can anyone shine light on these faults below.
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 77
VIN: ******************** Mileage: 255040km/158474miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 1010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HM HW: 028 101 227 8
Component: R4 2,0L EDC G000AG 7000
Revision: 12345678 Serial number: SEZ7Z0E2911912
Coding: 0050078
Shop #: WSC 06402 785 00200
VCID: 75EBFF0D1CDA171
7 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
P0671 - 000 - Electrical Fault
Freeze Frame:
RPM: 1533 /min
Torque: 52.0 Nm
Speed: 0.0 km/h
Load: 16.1 %
Voltage: 14.59 V
Bin. Bits: 00001100
Temperature: 10.8°C
Bin. Bits: 10110000
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 1533 /min
Torque: 52.0 Nm
Speed: 0.0 km/h
Load: 16.1 %
Voltage: 14.59 V
Bin. Bits: 00001100
Temperature: 10.8°C
Bin. Bits: 10110000
17058 - Cylinder 4 Glow Plug Circuit (Q13)
P0674 - 000 - Electrical Fault
Freeze Frame:
RPM: 1533 /min
Torque: 52.0 Nm
Speed: 0.0 km/h
Load: 16.1 %
Voltage: 14.59 V
Bin. Bits: 00001100
Temperature: 10.8°C
Bin. Bits: 10110000
16618 - Boost Pressure Regulation
P0234 - 000 - Limit Exceeded (Overboost Condition)
Freeze Frame:
RPM: 2562 /min
Torque: 358.0 Nm
Speed: 102.0 km/h
Load: 98.0 %
Voltage: 14.44 V
Bin. Bits: 00001000
Absolute Pres.: 2315.4 mbar
Absolute Pres.: 2590.8 mbar
16785 - EGR System
P0401 - 000 - Insufficient Flow
Freeze Frame:
RPM: 1596 /min
Torque: 18.0 Nm
Speed: 0.0 km/h
Load: 10.2 %
Duty Cycle: 14.7 %
Bin. Bits: 00001100
Mass Air / Rev.: 295.0 mg/str
Mass Air / Rev.: 510.0 mg/str
16485 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Freeze Frame:
RPM: 1260 /min
Torque: 0.0 Nm
Speed: 62.0 km/h
Temperature: 20.7°C
Absolute Pres.: 1050.6 mbar
(no units): 85.2
(no units): 0.74
Temperature: 86.4°C
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 798 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001100
Torque: 152.0 Nm
Torque: 0.0 Nm
Readiness: 1 2 0 0 0
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 041 HW: 02E 927 770 AD
Component: GSG DSG 041 0814
Revision: 04004010 Serial number: 00000502020117
Coding: 0000020
VCID: CFA7EDE55EC68D1
2 Faults Found:
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 -
18149 - Clutch Pressure Adaptation
P1741 - 002 - Limit Reached - Intermittent
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0006786
Shop #: WSC 00118 476 92217
VCID: 3A712C317544B89
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 C
Component: ClimatronicPQ35 006 0203
Shop #: WSC 00000 000 00000
VCID: 30650E19A338729
No fault code found.
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001430111
Coding: 81888F2700041000001E00000000000000007F0B5C
Subsystem 1 - Part No: 5P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 00000
2 Faults Found:
01049 - Supply Voltage Term 50
006 - Short to Plus - Intermittent
01518 - Bulb for Back-Up Lights; Left (M16)
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: S5 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD06RHMM
Coding: 0021301
VCID: 2C5D1A698F10169
2 Faults Found:
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
008 - Implausible Signal - Intermittent - MIL ON
010 - Open or Short to Plus - Intermittent - MIL ON
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 G HW: 1K0 953 549 G
Component: Lenksäulenmodul 021 0050
Coding: 0012042
VCID: 36693801415C5C9
Part No: XXXXXXXXXXX
Component: Lenkradmodul 004 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 930 A
Component: KOMBIINSTRUMENT VO3 1060
Coding: 0002401
VCID: 2D5B176DB40A1F1
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700105205004A
Coding: 3F3F07C0078203
VCID: 2953E37D80E2031
1 Fault Found:
01332 - Door Control Module; Passenger Side (J387)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 133
Mileage: 253678 km
Time Indication: 0
Date: 2000.00.00
Time: 20:06:16
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 1060
1 Fault Found:
01176 - Key
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1T0 959 701 A
Component: Tuersteuergeraet 09 0140
Coding: 0000016
VCID: 356B3F0D5C5A571
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.10 1502
VCID: 31630B1DA8327B1
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C000BC090005054C5F863000D4
VCID: 79F3F33D30C2731
Subsystem 5 - Part No: 5P0 951 171 C
Component: Innenraumueberw.009 4865
Coding: 00000000
Shop #: WSC 00000
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Component: NGS n.mounted
1 Fault Found:
00896 - Trunk Lock Unit (F256)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1T0 959 702 A
Coding: 0000016
2 Faults Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
00942 - Exterior Mirror Retract Motor; Passenger Side (V122)
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P2 035 186
Component: Radio BVX X012
Coding: 0042400
VCID: EED95061F98CA49
1 Fault Found:
00870 - Bass Speaker Front Left (R21)
011 - Open Circuit - Intermittent
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0216
Coding: 0000016
VCID: 2F670D65BE066D1
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000016
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 5P0 919 283
Component: 0F Einparkhilfe 0101
VCID: F5EB7F0D9CDA971
1 Fault Found:
00437 - Right Rear Inner Parking Aid Sensor (G335)
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 HW: 5P0 862 335
Component: FSE_2P5x H18 0030
Revision: 00000001 Serial number: 00000000174906
Coding: 0000555
VCID: F0E54E19E3B8B29
End ---------------------------------------------------------------------
Chassis Type: 1K0
Coding: 0050078
7 Faults Found:
Freeze Frame:
RPM: 1533 /min
Torque: 52.0 Nm
Speed: 0.0 km/h
Load: 16.1 %
Voltage: 14.59 V
Bin. Bits: 00001100
Temperature: 10.8°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 1533 /min
Torque: 52.0 Nm
Speed: 0.0 km/h
Load: 16.1 %
Voltage: 14.59 V
Bin. Bits: 00001100
Temperature: 10.8°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 1533 /min
Torque: 52.0 Nm
Speed: 0.0 km/h
Load: 16.1 %
Voltage: 14.59 V
Bin. Bits: 00001100
Temperature: 10.8°C
Bin. Bits: 10110000
Freeze Frame:
RPM: 2562 /min
Torque: 358.0 Nm
Speed: 102.0 km/h
Load: 98.0 %
Voltage: 14.44 V
Bin. Bits: 00001000
16785 - EGR System
Freeze Frame:
RPM: 1596 /min
Torque: 18.0 Nm
Speed: 0.0 km/h
Load: 10.2 %
Duty Cycle: 14.7 %
Bin. Bits: 00001100
Freeze Frame:
RPM: 1260 /min
Torque: 0.0 Nm
Speed: 62.0 km/h
Temperature: 20.7°C
(no units): 85.2
(no units): 0.74
Temperature: 86.4°C
Freeze Frame:
RPM: 798 /min
Torque: 28.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.29 V
Bin. Bits: 00001100
Torque: 152.0 Nm
Torque: 0.0 Nm
Coding: 0000020
2 Faults Found:
P1847 - 000 -
Coding: 0006786
1 Fault Found:
Coding: 00056272
Shop #: WSC 00000
2 Faults Found:
Coding: 0021301
2 Faults Found:
Coding: 0012042
Coding: 0002401
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 133
Mileage: 253678 km
Time Indication: 0
Date: 2000.00.00
Time: 20:06:16
1 Fault Found:
01176 - Key
Coding: 0000016
1 Fault Found:
Component: KSG 0401
Coding: 00000000
Shop #: WSC 00000
1 Fault Found:
Coding: 0000016
2 Faults Found:
Coding: 0042400
1 Fault Found:
Coding: 0000016
Coding: 0000016
1 Fault Found:
Coding: 0000555
