it could be a glow plug
you can check them with a circuit tester for continuity
remove bridge loom and connect one end of the circuit tester to battery positive then the other end to the glow plug
if it lights up then the glow plug should be ok
the bridge looms play up and i would replace that it connects in the plastic trunking behind the battery
