DIAGNOSTIC TROUBLE CODE (DTC) - P0462 FUEL LEVEL SENSOR LOW VOLTAGE
Details of the Circuit
· Using inputs of fuel level from the Fuel Level Sensor, the engine control module (ECM) calculates existing vapor pressures within the fuel system.
· With varying fuel content vapor pressure shows a marked change.
· To ensure proper functioning of evaporative emission (EVAP) system, it is imperative to calculate Vapor Pressure.
· Fuel Level helps to gauge whether it is capable of detecting extremities of existing EVAP system faults accurately.
· This Diagnostic Trouble Code (DTC) detects a stuck fuel level sender.
Pre-requisites of Setting the DTC
· Fuel Level Sensor voltage < 0.05V.
· Fuel Level Sensor circuit low voltage.
What happens when DTC sets?
When will DTC clear?
1) The Malfunction Indicator Lamp (MIL) will not glow
1) A history DTC will be removed after 40 successive warm-up cycles without any fault
2) The ECM will
store the previously recorded conditions of the DTC as Failure Records data only.
2) DTC(s) can be cleared using the scan tool
3) This information will not be stored in the Freeze Frame data.
DTC P0462 - Fuel Level Sensor Low Voltage
Found this thought it might point you in right direction?, also look at bba-reman for some sort of check list process,
